Rusty filler neck in 1991 Cabriolet.
(In Topic #89604)
Seanie
Seanie,
'Better to wear out than rust out'
Its pretty hard to get hold of a cabbie filler neck nowadays. Normally you'd have to get one fabricated. The best way is to source a tintop filler neck and adjust that (I think it involves cutting some of the bottom of and using some rubber tubing). You should be able to get a filler neck from Crazyquiff at www.golfmk1.co.uk
Mk1 GTi White Cab '86
Mk4 TDi
Mk4 TDi
29320 FUEL FILLER NECK G1C >84 (>Ch.15E011290) 33.00
29320 FUEL FILLER NECK G1 >12/83 33.00
29321 FUEL FILLER NECK G1C 84> (Ch.15ZEK011291>) 96.00
the latter being gold plated
Seanie,
1990 MX5 Mazda
2003 VW Passat 130 Sport
Sylva Fury 'blade powered…
Yorkshire Region Host
Mk1 Cabriolet 1500 (under resto)
Mk1 GTI
Mk1 GTI
Seanie,
Check it…
hope u and cabby are good!
'83 Black GTI Cab on BBS RAs - DreamBoat 3000'
Resto = http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=67552
Seanie,
