Rusted fuel pipe (to tank)
(In Topic #77946)
The fuel filler pipe has rusted through just inside the filler cap and the constant slamming in of the petrol pump nozzle has broken through hence the spillage at the garage.
Can you tell me if this is a big job to sort? Can I just get the pipe from filler cap to tank replaced or is it more than this? Any idea of the parts cost as well?
Appreciated!
Simon
http://cgi.ebay.co.uk/VW-Golf-Mk1-Fuel-Filler-Neck_W0QQitemZ4625954725QQcategoryZ9889QQrdZ1QQcmdZViewItem
http://cgi.ebay.co.uk/MK1-Golf-GTI-Fuel-Filler-Neck_W0QQitemZ4625451566QQcategoryZ9889QQrdZ1QQcmdZViewItem
Marc
Mine was pretty bad :
Shouldn't take more than about an hour to get the old one off and fit the new one, but make sure you drain your tank first!!
Mike.
1983 White cabriolet GTi
I also got the underseal out, and undersealed all around the areas on the inside of the rear quater where it attaches to the car, stops any potantial rust starting there, or getting any worse if it already exists.
Website Manager
lhasadreams said
I guess your Golf was not a k-jet one then !!!
Otherwise you would of noticed it a long time ago.
Ade
Mine is a K-jet engine, but luckily none of the rust had fallen into the tank when I took it apart, as it was all held together with rather a lot of mud. I disconnected the pipe at the bottom first before interfering with it, so any rust that did fall down the pipe didn't end up in the tank.
Mike.
