Replacing fuel pump
(In Topic #78010)
Replacing fuel pump
today it turns out that my fuel pump is dead,
the relay is fine there is 12V going to it when the ignition is on,
but the pump does nothing,
how hard is it to replace the pump,
i have ordered one, which will be arriving tomorro, so i intend on fitting it tomorro too,
can some one talk me through what is required to do?
im worried about gettin fuel every where,
also is the pump in two parts? only will be replacing one of them?
thanks alot
Tim
mk2 1.8 Driver
mk1 1.8 16v on Carbs
there are two wires comming off the pump, one is live i take it the other an earth,
where is the earthing point?
i get 12v over the pump when i put a meter on it, but the pump does nothing,
tim
mk2 1.8 Driver
now the pump is off the car, if i put volt meter over the two wires that were attached to it, i should get a reading of 12v when ignition is on?
i have also put 12v over the fuel pump off the car to see if it would prime, but it did nothing,
tim
mk2 1.8 Driver
then once you crank/start the engine it recieves a feed of the coil
to keep it running so if the car is in a crash when the engine stops so does the pump :wink:
my facet pump is on the way!
mk2 1.8 Driver
1983 lhasa green mk1 1.8 gti
old skool baby
old skool baby
pump is off, i found two valve type things from a brake bleeding kit to block the ends off while there is no pump there,
i pick up my pump tomorro along with a new twin cable throttle linkage 8)
mk2 1.8 Driver
