reccommend a performance manifold please
(In Topic #121922)
Member of the month GET YOUR SAY IN NOW
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=86608&highlight=
is it def for a mk1 thou
westy117 said
pipe sits really low about 1 1/2 inches off the floor, standard 1.8 8v gti on 13inch wheels with coilovers
Just use the standard manifold, you'll see no gain with an aftermarket one on a standard engine. And you'll save money and fitting hassles too!
On my second trip around the block with the new cab, I completely failed to find an exhaust that would fit and reverted to OEM parts. The outcome was less cash outlay (£60) and no exhaust fumes in the car.
Tim
Most are ill-fitting and not worth the £150(ish) that they cost.
The performance is not improved and they tend to fight for space with either the steering column or/and the off-side drive shaft.
Tim
agreed. i had an ashley 4 branch on a standard engine. no gains, or very minimum at best. the bloke at rally design will tell you that before he sells you one too.paul_c said
My motor has polished and ported head, matched to the manifolds with a piper 290 cam, custom SS exhaust (minus manifold/downpipe) and K&N filter. I also have a 1600 metering head, audi throttle body and 16v WUR to fit when when I get time.
Once the inlet manifold has been attacked with a grinder/polished internally and opened up for the TB I would expect a heat wrapped performance manifold to compliment the mods I have once all fitted and fuel pressures checked/set and the car RR tuned as per paul c's recommendations i've previously read.
Hence my curiosity. I'm in for keeping this car for quite a while so would prefer SS for corrosion issues etc.
