re. ajusting idle speed
(In Topic #83905)
i have no end of problems with my clipper and i'm about to start hammering it to bits its an 89 1.8 carb model and i was having a fuel problem first the car was losing power then would conk out then i changed the plugs leads dissie and filters, the problem went for a little while then i had a new problem everytime i went up a hill it would conk out so on some advice from the AA they said the fuel pump had gone so i fitted a new one no change since then i have had the car in bits been inside the fuel tank looking for rust which i found a very small amount which has been removed with only three main parts left to change i changed the little fuel reservoir but now the idle speed has gone really low in fact so low in switchs the car off i wanted to try and ajust the idle speed but i can't find anywhere to change it any idea's?
