problems filling with fuel
(In Topic #128542)
Any helpful suggestions would be great, thanks in advance. :dontknow:
Early-1800 said
Are you sure its empty before you try refilling? The gauge might be vastly under reading?
I'd go with that too…
when it is telling you the tank is empty, take the cap off and rock the car back and forth. If the tank is only taking 10 to 12 quid, you should hear plenty of fuel sloshing about! Perhaps you bent the float arm on the sender unit if you have had it off?
My Build Thread
thanks for your suggestions.
Fixed one fault got another
