Possible fuel blockage...
(In Topic #75587)
I believe it may be a bad fuel line, but this is my first mk1 so not if this is a common problem…any comments or help would be appreciated.
Cheers, Jon
BTW its an '83 1.3 Golf Driver, if that makes any difference! :?
Carb icing - do a search on this forum for more details
Weak fuel pump - only real way to test is to replace
Blocked fuel lines - could be blocked filter - cheap and easy to replace
Incorrect setup on carb - Float position and adjustment
I have a used 1.3 fuel pump if you want one for not much.
Rich
Have a look in the tank via the inspection hatch/fuel sender with a torch.
One of my Drivers did the same, would run for about 5-7 miles then conk out. Blowing back down the pipe from the tank cured it temporary for another 5 miles. The eventual solution was to take the tank off and swill out the crud. The Carb tanks are not as easy to clean out as the injected versions unfortunately?.
Jon
Sloved it by removing the fuel return pipe from the carb and pluging it! 8O
Car ran sweetly after that until I eventually stuck a bigger engine in…
My Build Thread
Not a 5 min job to replace. I'd recommend getting a replacement filler yourself and then ask a garage to fit it (unlike me who got a garage to source one at a seriously elevated price :cry: ).
You should drink more water.
1664 is 95% water.
Drink more beer?
1664 is 95% water.
Drink more beer?
Jon
Tested the pump on the roadside and it wasn't getting any fuel, took out the inline filter and it was fine, does this sound like a blocked line?
