please help, petrol leaking everywhere
(In Topic #85670)
As soon as i took the battery leads off, the problem begin to lessen until it eventually stopped, the tank still has plenty in it….
checked in the engine bay and a pipe that connects between the carb and somewhere in the middle of the block by the bulkhead had come off, put it back on took it for a drive again…same problem… got home, turned it off…fine, then workign on car for abotu 20 mins it starts going again
Its coming out of a small plastic pipe from the side of the tank, and infront of wheel well, i assume this is som\e type of overflow, is something blocked? what should i look for/fix
I cant find any useful info anywhere as its all for gti's (all injection and completely different)
Fuel is leaking a bit from the carb but not enough to worry about, just bcos its crap more than anything…
hope someone can help as it really is pouring out…
also found a bell shaped peice of rubber on my drive, ive seen it b4, that goes on the end of a pipe, i assume this just directs the fuel overflow as opposed to spraying all the underside of my car?
thanks for any comments or suggestions
thanks very much
Josh
what wud b causing the fuel to reach here in the first place?
ta
Josh
1983 1100 C
1983 1100 C
im really really stuck with this problem, and haynes is no help whatsoever!
ta
Josh
Have you seen this thread http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=20918 ? Got a diagram of the breather system you should have. Gravity valve is no 40 and pipe over the rear of the tank no 9. You could try removing all the breather hoses and checking for damage or blockages.
1983 1100 C
1983 1100 C
