Petrol/fuel tank differences?
(In Topic #140721)
Got to take out and repair my fuel tank as its got a hole, or just buy a replacement, which is prob easier as i cant weld or even own a welder………..which maybe i shall rectify one day being a mk1 owner :wink:
Anyway if im looking to replace will any mk1 golf fuel tank be ok? Mine is a gti tin top on an 82 reg so series 2. Will cab, non injection tanks be the same?
Just to add mine is running bike carbs with a facet fuel pump. That may make a difference if the tanks vary between carb and injection models?
Thanks,
Dean.
Had done a search and pretty much gathered that ( should of searched first!! :doh: )
Gonna have a go at repairing first….cheaper option!
Basically im gonna do a temporary patch using petro patch. I just need it to hold the fuel whilst I get the facet pump up n running and sort out any issues etc.
Then when its at the body shop I shall either remove and ask them to weld or buy another one. Not gonna buy used as could end up with the same problem in a few years so would rather spend the extra on new. Or saying that get this one patched and put in a tank lining kit. POR do them and from what ive read its good.
rubjonny said
needs to be mk1 gti tintop tank specifically, these have internal swirl pot and outlet on the bottom. carby wont work unless you also add live pump and reservoir from late mk1 cab/rocco injection. diesel tank is similar but no swilr pot so not a good idea as it might kill the fuel pump as it could run dry when cornering
which is better purchase? a GTI tank (presuming this has everything included) or adding the later bits to a carb tank?
