Petrol/fuel tank differences?
(In Topic #140721)
Hey guys n gals,
Got to take out and repair my fuel tank as its got a hole, or just buy a replacement, which is prob easier as i cant weld or even own a welder………..which maybe i shall rectify one day being a mk1 owner :wink:
Anyway if im looking to replace will any mk1 golf fuel tank be ok? Mine is a gti tin top on an 82 reg so series 2. Will cab, non injection tanks be the same?
Just to add mine is running bike carbs with a facet fuel pump. That may make a difference if the tanks vary between carb and injection models?
Thanks,
Dean.
Thanks,
Dean.
needs to be mk1 gti tintop tank specifically, these have internal swirl pot and outlet on the bottom. carby wont work unless you also add lift pump and reservoir from late mk1 cab/rocco injection. diesel tank is similar but no swirl pot so not a good idea as it might kill the fuel pump as it could run dry when cornering
Thanks once again RJ.
Had done a search and pretty much gathered that ( should of searched first!! :doh: )
Gonna have a go at repairing first….cheaper option!
watch it, petrol fumes + welding = danger will robinson!
thats cool then, just a case of make sure it has some kind of swirl pot since some of the cheap pattern tanks dont
worst case you could add the lifter pump and a swirl pot underneath, that way you can just get a bog std carby tank. bit of a pain though as you'll have to splice into the main pump wiring and add a 3 pin plug for it (can use the headlight adjust motor plug off mk2 golf, they all have them)
lol.
Basically im gonna do a temporary patch using petro patch. I just need it to hold the fuel whilst I get the facet pump up n running and sort out any issues etc.
Then when its at the body shop I shall either remove and ask them to weld or buy another one. Not gonna buy used as could end up with the same problem in a few years so would rather spend the extra on new. Or saying that get this one patched and put in a tank lining kit. POR do them and from what ive read its good.
rubjonny said
needs to be mk1 gti tintop tank specifically, these have internal swirl pot and outlet on the bottom. carby wont work unless you also add live pump and reservoir from late mk1 cab/rocco injection. diesel tank is similar but no swilr pot so not a good idea as it might kill the fuel pump as it could run dry when cornering
which is better purchase? a GTI tank (presuming this has everything included) or adding the later bits to a carb tank?
whatever comes up first
Hi , my tank is leaking and have been looking at putting a new one , but have onl been able to find non injection tanks. What options are there?
see my first reply
