Not Starting when hot
(In Topic #148161)
GTI Campaign Helios Blue, Going back Standard
GTI Campaign Schwartz Black shouldn't have sold
GTI Mk7 Performance pack Daily drive
Polo 1.4sel Sunset Orange The Wife's
Triumph Tiger
Triumph Tiger
Triumph Tiger
Triumph Tiger
thanks
Chairman
I too have this problem but wa thinking more along the ignition route.
Jacob, does your car start with a push/ bump start? Mine does so I was think possibly electrical.
as for op problem this can also be down to a failed non-return valve in the fuel pump as well as faulty accumulator
rubjonny said
csv should only fire when the engien is cold, so that suggests a failed csv thermoswitch.
Thanks mate it it was the thermo time switch. Thanks to all others that commented
Chairman
Are we saying to disconnect number 2 in the diagram next time the hot start, non firing issue occurs??
Ta.
Chairman
The green and white wire looks ok. It runs into the loom as it should without breaks but something could be breaking down inside I suppose.
Chairman
There doesn't seem to be any pattern. In Germany Id pull up to the pumps to refuel and it would start, move off and park up for a 'comfort break' and on return it wouldn't start. Same again after the run back from Wolfsburg. After a 30 minute break to get changed it wouldn't start again. Before we even left for Germany I went to fill up, came home, parked and after 30 minutes its so went to set off and it didn't start!!! All I did was roll it backwards slightly and it started. Very strange.
Ive replaced the battery and alternator - pre Germany.
It will start in the bump start so I was thinking maybe ignition issues. The thing is, it's so adhoc I can't plan to be anywhere to check it over when it happens!!!
Chairman
I'll try and remember to have a small screwdriver to flick the clip off… And a tissue to mop the undoubted blood that issue as a result of tinkering with the engine!!!
Chairman
We've just not had the time to get together to test it.
How do I know if the accumulator is faulty???
the non-return valve is the part the fuel line attaches to on the fuel pump, once the line is removed the non-return valve can be unscrewed. its also possible that the NR will unscrew itself if you try to undo the fuel line if the end nut is stuck
Chairman
I'll have a look at the manual and see what I can read up on. When the valve is unscrewed is fuel likely to flow out? An I best doing this with a low amount of fuel in the tank??
