Non starter
(In Topic #94214)
Non starter
Hey ,ive got a '03 life with some fueling problems .it is crankin when i try to start it but doesn't want to fire .ive checked timing and spark but still nothing! When i switch the ignition on i should be able to hear the fuel pump for a few seconds but it is completely dead..Ive checked my fuses but they all are okay ,i even had a new pump on but its doing the same thing. Can sumone please please help me! :cry:
what engine have you got there?
1982 Non Sunroof Black 1600 GTI
2003 MKIV Golf PD150 GT TDI
Its a 1600 engine
Obvious thing would be to check the fuse (its the one on top of a relay, which is the fuel pump relay). If its not this, then bypass the fuel pump relay (fit a wire and switch in between the 2 big terminals) and listen out for the pump.
Ive checked evrything even changed the ECU but nothing! When i try to run a wire straight from the positive of the batry onto the live of the pump i can hear it and my engine runs but bypassing the relay doesnt seem to work
Hang on…. 03 - 2003?
The Mk1 Golf doesn't have an ECU….
Im from south africa dude and here our mk1's do have ECU's
