No petrol from tank
(In Topic #87070)
No petrol from tank
what's the easiest/simplest way to sort this petrol prob? Don't fancy taking tank off, still got fuel in.
The engine runs from another petrol source (petrol can) so pump etc OK. New filter too.
anything simple I should look at?
Not too mechanically minded I'm afraid.
ta
CC
edit: - im assuming there is actually petrol in the tank
mk1 1.1 C
You can just see the fuel sender poking out of the hole about where the drivers side rear seat would be in this pic: -
Once you've got it off grab a torch and look inside to examine the state of the tank. You may be in for a nasty surprise - I certainly got one, and ended up having to buy a replacement tank. Try Crazyquiff or Scouse on here for one if you do need one.
HTH
Rich
just what I was looking for.
I got a spare filler neck with the car so guessed there was problems there.
Nice one
roll on sat morning
