No fuel getting g to injectors
Are you doing this test with the pump constantly running?
When you say constantly running do you mean ignition on .?
an easy way is to fit a 17/18 relay to the fuel pump socket if its a later blade fusebox, this will make pump come on with ignition. pull the black wires off the coil to stop any chance of a spark while testing
So just jump across the two big blades on fuel pump relay position in fuse box .?
When the car was working before the rebuild never a fuel pump sound silent running but now I've bridged the relay it sounds really loud buzzing still it pumps
But my fuel filter unions are still leaking even after …
- new copper washers
- new aluminuim washers
- annealing the copper ones
Could there be a fault with metering head causing back pressure that the banjos simply can't handle .?
look for obvious problems such as kinks etc, and if you see rust anywhere in the fuel lines its best to just bin EVERYTHING and start again once the fuel tank and filler neck are cleaned and replaced. trouble with rust is once its in the fuel system its difficult to remove and knackers the metering head as the clearances inside are so tiny.
you could remove the lines to the wur while you're there look inside the inlet hole make sure the mesh is clear
1)tanks been removed cleaned
- filler neck wasn't rusty
- new filler neck to tank rubber
- new crazy quiffs main fuel lines
- brand new Bosch fuel pump
The whole engine was removed to clean and sort tappers out etc
Car was running fine before removal
Have replaced everything back again same wur same metering head but no fuel to injectors it's getting to metering head and when I undo. The banjos for Injectirs fuel comes out its been suggested as I can't get fuel filter to seal that maybe lowering pressure to I he toes so they won't open .??
Any tips on sealing filter banjos .?
Could it be …..
- faulty filter
- blockage metering head side of things causing back pressure. To filter banjos
I assume fuel pump doesn't have pressure regulator .?
Filter is brand new Bosch
Dowty washers finally sealed the filter then did injector test sure enough lifted flap and injector fired into coke bottle
Eventually engine started but nowI have the dreaded cold start issue
Could it be …….
5th injector
Isv
Thermotime switch
Aav
That's at fault how do I test these .??
Swapped injectors out still no joy any ideas .?
