mpg
(In Topic #72524)
![stuGti16 in the usergroup ‘Local’ stuGti16 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
mpg
i've just got my car on the road well new years day after a years worth of rebuild it's a 1.6Gti and i manged to get just over 29mpg but not sure how good that is ?
i had a few drives where i accelerated enthusiastically but as it's a partly fresh engine i don't wanna push it ! (it has been run in)
is the fuel pump meant to run all the time ?
Cheers Stuart
www.msportcam.co.uk
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20160605_084816191_iOS.jpg)
![Hairyarse in the usergroup ‘Moderators’ Hairyarse in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Hairyarse in the usergroup ‘Paid Member’ Hairyarse in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Hairyarse in the usergroup ‘Regional Hosts’ Hairyarse in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Hairyarse in the usergroup ‘Local hero’ Hairyarse in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
The fuel pump does always run - or you'd get no fuel.
![turbtechnicsMK1 in the usergroup ‘Old timer’ turbtechnicsMK1 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Remember when I used ot go to Inters at TRL, and had to leave with a full tank and then fill up before coming home !!
Fuel pump, yep as soon as the engine starts to turn over the pump is running and stays running untill the engines switched off
Guest user
![loughy in the usergroup ‘Regular’ loughy in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
mpg
So :? thats aorund 28 mpg?
Mind you the MFA reads between 15-20 :cry:
If Its Loud and Noisy , I'll take its picture
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/AVATAR.jpg)
![AL_Mk1 in the usergroup ‘Local hero’ AL_Mk1 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Re: mpg
Was that the reading on the MFA or did you calculate it?
My Build Thread
only reason i asked about the fuel pump was some cars when you turn the ignition on run and build up pressure and stop until started.
i will rolling road it when i'm back at college and see what the fuellings like see if i can make it run any better !
Cheers for your replies
Stuart
www.msportcam.co.uk
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Golf%20Ava5.jpg)
![markwon in the usergroup ‘Local hero’ markwon in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
1983 1100 C
1983 1100 C
out of all the higher octane fuels i believe that bp ultimate is better than optimax as optimax loses it's potency.
i managed better efficiency and my car felt more responsive when i used it in my mazda 323 turbo so always worth a try.
i think i will be using some 4 star mixed with unleaded.
stuart
www.msportcam.co.uk
![nickvw in the usergroup ‘Local’ nickvw in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
MK1 Golf GTI 1900
MK2 Jetta GTI 16V
MK2 Jetta GTI 16V
![Maniac in the usergroup ‘Old timer’ Maniac in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Mind u that is with fairly 'good' driving as I don't like to push my car too far, I like it too much! The MPG on the MFA readout gave an average reading of around 69mpg! How in-acurate can it get!
1983 White cabriolet GTi
