mki 1800 gti cab keeps stalling please help
(In Topic #77484)
welcome any help
cheers Paul
Mines in at the garage on wed to get checked out, im thinking fuel issues at the mo but il let you know when/if i get any reports of what they think
Iain
He owns an Honda S2000, (very similar engine to ours!)he had the problem with a heat build up around the engine and solved it with a snorkle!
the basics…when sat a still in the car, the heat builds around the engine obviously, this warm air sucked into the engine mixes with the fuel and changes the mixture. So, i think my car was running rich anyway and with the added low density hot air, causes the car to give up unless it cools slightly or you manage to drive it fast enough to get a staedy flow of air in to the engine.
I think i am going to have my carb adjusted and sort out some of the tuning issues…and drive around with no bonnet!!! She'll never overheat then!
Il keep you posted on what the so called 'experts' say.
Anyone got any more ideas or am i talking bollocks??
Iain
One HOT cab…literally
My GTI did exactly the same….turned out to be a clogged lift pump filter…..went a dream after doing this……
Remove plate (under rear seat)….
Remove hoses and rotate the sender unit….(use a wooden drift)…
Mine was like this….
How it should be….
Check / replace the 'O' ring when putting it back together….
Could that be my kangarooing problem?
paul 8)
mawwam said
Are the clipper 1.8 carbs supposed to have this? I had mine apart the other week, and my sender unit is just the two pipes that go down into the fuel !!!
…no, only GTI's after '85/6 or thereabouts ….
The hunt goes on
Ok mate, thanks for info
