Mk1 Cabrio performance downpipe
(In Topic #88142)
Volkswagens With Attitude
badvwboy said
in terms of the egine i have ported the head for better flow and i am running a audi 2ltr bottom end combined with uprated plugs and leads and a custom air intake, so may be a ashley manifold, will it bolt straight on to the miltek exhaust, are all these things std lengths?
not standard lengths as such, but they do have joining pipes that should btotal the same length as a downpipe.if i recal correctly, the ashley ends in standard pipe diameter, so if the miltek fits to standard downpipe, then yes, it should fit o.k. if you do go ashley, match the ports to the head, as they are a bit irregular. i'd still go for one with smaller primaries ,if i were you.
is it useable power with the mods?
cheers damo
