magnets !!! on my tank
(In Topic #76405)
before i get to do this i need to drive the car for around 100miles,
the car runs totally sweet at the moment, so i dont want to balls it up…
1* are the dangers of rust in the tank less harsh on a carb engine ?
2* is a cleverly placed magnet a way to prevent contamination of the fuel system
1981 mars red gti
2001 new beetle
1990 clipper
1981 1500 gls
2001 new beetle
1990 clipper
1981 1500 gls
in line
Would advise tank is empty or very minimal amount when you do it! 8O
Re: magnets !!! on my tank
Not really, since rust isn't magnetic.
When your fuel filler neck corrodes it doesn't form an air tight seal anymore.
The splits open and, because it's near the rear wheel arch, water gets kicked up off the rear wheel and gets into the fuel tank.
Water isn't magnetic either!!
you really need to get the tank out of the car and flush it out - you can either empty the tank and let it dry - give it a good side ways shake and then all the rusty fragments will be central in the tank and then just hoover em out.
on reinstalling my lifter pipes and sender unit i installed a simple plastic inline filter fixed onto the end of the lift device - this works very well as we had done this about 10 years ago when we owned the car previously.
if there is rust in the tank take the tank out - it isn't a massive job - you'll need to drop the axle slightly though…
rusty fragments in your fuel supply will be equally as damaging in a carb car as in an injection version
