Leaking fuel and loads of back pressure from tank? HELP!
(In Topic #88588)
1982 Golf Cabriolet GL SOLD!
2005 Renault Modus 1.5 DCi
2004 Renault Grand Scenic 1.9 DCi
1985 Land Rover 90 200Tdi
Pressure [slight is normal] to the tank is normal , it helps the pump keep fuel to the engine . But look in the drivers wheel arch you will see a 'Gravity valve'
this must be the correct way up and free from obstructions , it also keeps the tank from pressurizing and causing the problems you have .
me too!
