Idle Contral
(In Topic #74994)
Idle Contral
Can someone tell me what size bolt the Idle contral screw is?
thanks
mick
Is there a plastice cap or anything covering it as i do not seen to be able to move it
thanks
mick
If it isn't covered, but won't turn easily, it might be turned in all the way to the end of the threads (jammed), probably by someone who wanted the idle speed even lower, (but didn't realise that there was an air leak somewhere else in the intake/vacuum system, keeping the revs up)
thanks for that, i will look into the intake/vacuum system next
thanks
mick
Well worth printing off and keeping with your Haynes manual
K FUEL INJECTION EXPLAINED
Also explains some of the mysterys
Cheers………
chudd said
Mick have you seen this site ?
Cheers………
thanks chudd
