Iced Petrol!
(In Topic #72292)
Iced Petrol!
Filled up car on way home the other day.
Parked, facing up the hill.
Walking past the car last night I noticed ice under the petrol cap! Weather miserable but not frosty.
I picked it out and it was frozen petrol!
I took the cap off and basically the petrol level was right to the brim and was leaking out of the cap and mixing on the outside with the rain making a frozen petrol type mixture!
Any hypothesis on the Physics at work is welcome.
Suppose I better check that aswell as petrol getting out that water can't get in through cap!
Peter.
1980 1600 GTI, daily driver.
I'm not sure what sounds best tho, 'Iced Petrol' or 'Petrol Ice?'
Life Member
Here's a tip for making some quick icecubes for cocktails (the fiery kind). Pour water about an inch deep in a container on a cold day. Add petrol to the water - within a minute or two the water will freeze. Pour off the petrol (don't burn it off as you may melt the ice) and hey presto ice.
Warning: Do not try this as you will either burn yourself down or poison yourself. Either way you'll probably die.
Life Member
I am sure the frozen stuff is still ice not petrol though like you say for making the ice cubes!
Cool.
REAL cool
Mk1 GTI
B5 Passat Estate 5 SPeed
Bosch Lawnraker 32
Bosch Lawnraker 32
