How to remove fuel filler neck???
(In Topic #82314)
How is this done??
Can I block up the fuel tank then to make it safe to get the welding done??
i'm going to be absolutely no help at all here but i have the same problem.
just hope this reply might bump the thread up a place or two as i need the same info.
sorry i'm no help.
Are you sure the rust (requiring new panel?) only extends around the filler cap, or do you need a bit more in the inner (mid) wing? If its more, then you would have to drop the axle and tank. I think you'll find a little more!!!!
