Help with part numbers
Does anyone know the following PNs?:
fuel filler neck to body rubber seal for a '76 (holds the neck in place, not just a gasket). Dealer tried various parts but no luck yet.
fuel cap seal for a '79 (fuel cap is quite rare non locking screw in type)
Rajan
Think i may have a new screw in fuel cap, not sure if its locking or not though, will have to check
Yo Dubs
Your fuel filler neck to body rubber seal could be
"Retaining Ring for Fuel Filler Neck" 171 201 681D
There is also a "Ring for Fuel Filler Neck" 171 201 141
There is another "Sealing Washer" between the flange on the filler neck and body side: 171 210 119F (Carb models).  Mine looks to be made of Leather rather than rubber
I suspect the actual gasket on the cap is 211 201 557
Hope this helps but its hard to tell on the ETKA pictures (sketches no less)
Mk1 GTI
B5 Passat Estate 5 SPeed
Riley 1071"S" Elf Mk2  (Bl**dy Hooligan machine!)
Bosch Lawnraker 32
Thanks Superworm - will check out these numbers.
Storm - interested if you have the fuel cap and its unwanted.
Rajan
dubbers,
Can probably get you a new screw in cap if wanted.
Rich
Crazyquiff's Mk1 Golf Parts Emporium
www.golfmk1.co.uk - you know you want to….
Okay i have checked the cap, its new and made by hella as was the originals i believe, its the scew in type and is locking, looks the same from the outside as the later fuel caps (not the campaign one's)
