help on fuel distributor
(In Topic #84856)
the one that is on the 87 cab has got a seized adjustment screw on it
83 1.5 gl all black sold
86 1.8 gti cab all black light mods. restoring
87 1.8gti cab standard helios blue. daily driver
91 1.8 auto cab gold clipper. breaking
1983 1100 C
1983 1100 C
1983 1100 C
1983 1100 C
did i read that you have a few spare ones around, if so how much for a working one ?
Wasn't me?
You're on about the co/mixture adjustment for the air-mass sensor plate loacted in the airbox. The metering head/fuel distributer is the metal block bolted to the top of it and controlled by the sensor plate.
Have you tried swapping over the just the airbox and keeping the same metering head? The adjustment of the sensor plate is quite delicate and it is possible for it to get damaged. I'd imagine that sensor plate would need a bit of adustment if moved from one car to another as they probably bed-in in different ways over time. Haynes does explain basic set up with a feeler gauge.
Have you opened your old airbox up and looked from inside as to why the mixture screw might be jammed?
1983 1100 C
1983 1100 C
