Help, can't find a manifold and it's blowing a goodun.....
(In Topic #84222)
MK1 GTI 8v cabby (Helios Blue)
MK1 GTI 8v cabby (White)
MK5 GTI Edition 30
Corrado VR6
MK5 GTI Edition 30
Corrado VR6
Regards Volkswarren
MK5 GTI Edition 30
Corrado VR6
MK5 GTI Edition 30
Corrado VR6
Regards Volkswarren
You wouldn't think I've owned a mark one for 5 years would you……
MK5 GTI Edition 30
Corrado VR6
MK5 GTI Edition 30
Corrado VR6
Regards Volkswarren
yea
Re: Help, can't find a manifold and it's blowing a goodun...
hope the fumes ain't got to much for you :tlc:rasputin said
Hi there, been trying for a week to get hold of a manifold for my mk1 gti cabby 89-90.
scouse has some and there is another for sale else where.
Regards Volkswarren
went for an ashley 4 branch in the end, thought it better to get a brand new one. Just need to find a reliable place to get it fitted
MK5 GTI Edition 30
Corrado VR6
MK5 GTI Edition 30
Corrado VR6
comes in 2 bits if that sounds right ? what else will i need for this ?
you reckon it might take a bit of tweakin to get sorted ?
MK5 GTI Edition 30
Corrado VR6
MK5 GTI Edition 30
Corrado VR6
Regards Volkswarren
volkswarren said
i've only had four branches snap and break weilds when its not had this joint on them, never had to modify and put a flexi section on. had a manifold around 10 years back without this joint and it snaped in less than 12 months, but since then we always fit a rear poly engine mount
I recognise that picture! :wink:
Are you saying you don't use a flexi section if the manifold has the bolt/spring section pictured? I have just got a flexi section to fit with the above manifold just to be on the safe side (I have a poly rear engine mount too)…
How tight are you supposed to do the bolts up? I guess the less tight you do them the more room for movement there is but not tight enough and exhaust gasses could leak…
Regards Volkswarren
