GTI not starting
(In Topic #134621)
GTI not starting
Since then if you attempt to start her, the first time she will almost catch. It'll sound like it's started, but then die away again. If you continue trying you'll get nothing. If you leave it a few minutes and try again, you'll get the same again, first time will almost start, then nothing. Here's what I've tried -
1. Putting easy start through the air intake she runs fine.
2. I've taken off the feed to the fuel filter and there's no fuel arriving there.
3. Fuse for the fuel pump is fine
4. I've replaced the fuel pump relay with a brand new one
5. I've replaced the fuel transfer pump (the one in the tank)
Even after all this, I'm still getting the same symptoms. Until now I hadn't bothered with the fuel pump thinking it was hard to get to. I've just gone looking and found it right next to the drivers side of the car. Listening down there while trying to turn the car over I can't hear anything coming from the pump. Saying that I can't hear anything from the fuel transfer pump either.
My next step was going to be to try replacing the fuel pump? Any thoughts?
If they are, and its not starting, then it could be the battery voltage is low. What happens is during starting, the voltage drops, then the fuel pump can't pump at high enough pressure to open the injectors and provide fuel to start the car. It can be jump started off a running car or push started though.
Today when I picked up the fuel pump relay I also bought a new battery. So with a brand new fully charged battery I tried it again, with the same result. So I'm fairly confident it's not the power to the starting circuit.
I have tried listening to both the transfer pump and the main fuel pump, and can't hear any noise from either of them. Not sure how audible they normally are but I've had my ear right next to the main fuel pump while the car was cranked (and nearly started) and still couldn't hear anything.
That help any?
Can I ask how you know so much about the Golf? Is there some resource I'm missing with all this info or just stuff you've worked out from playing with Golf's? However you know it, your help is much appreciated
DOOOOOOOOHHHHH!!!!!!
I have the red service manual for the cabby. The service manual has a pick of the relays and fuses on one diagram. Then underneath a table saying whats what. I looked at the table, it said fuel pump in position 5, so that's the one I replaced. Turns out i'm stupid. The table underneath the diagram is for the fuses, relay table is on the next page!! So it's fuse in position 5, and relay 2 I should be checking. Gave the relay in position 2 a tug, and it wouldn't come out. Turns out it had blown and was welded in place. Managed to get replacement and put it in, and vrooom, for first time in 3 months she fired up. :-)
Thanks for the help Paul. Now back to trying to fix the suspension, but thats a story for a different forum :-)
