GTI fuel pump in line pre filte
(In Topic #77960)
Just rebuilt my GTI fitted a new pump but some debris out of the tank went through the pump and jammed it. Wondered if any one had fitted a pre filter maybe off another car, any pictures would be a great help.
I found the biggest in-line plastic filter I could from an autojumble and plumbed it in. I put it in place of the short 90degree rubber hose that goes in-between the tank and pump. Space is very tight so I had to use some fuel hose and make loop about a foot across. Tank-hose-filter-hose-pump. I cable tied up it to I think the pump housing or some suitable convenient point under there!
This stopped the pump jamming and after about 2yrs/8000 miles I removed it and replaced the original hose. It?s been OK since.
I did something similar during the rebuild to get the engine up & running, I managed to find an injection filter off a new jag that was tapped m16 so was large bore made up some hose adaptors and simply tie wrapped it to the rear beam, then fit some long hoses, so now I am looking at a more permanent soloution, will probably use the same filter but to reduce the large hose bends I have seen some 1/2" steel 180 degree bends that are used on oil coolers, will carry out a trial fir and see if it will fit somewhere aroung the fuel accumulator.
