golf clipper fuel probs!!!
(In Topic #81208)
Here we go…
i have had the car for around three months now (its a 1.8 carb engine with a weber carb on it (not sure what one though)) and it has started to splutter and then eventually stall when i have been driving. i had a little read about and changed the filter, as it looked quite dirty, went out again and it did the same thing.
I know there is the pump near the air filter, but is there another one oand if there is should i change the one near the filter first and what sort of price are they??
sorry for the essay, any help much appreciated!! Stuart
we larve it larve it larve it larve it larve it!!!!!
you can get a new tank from gsf, euro car parts, or try crazyquiff,
when you change the tank get yourself a new fuel filler neck as they rust like mad
ans4r 8)
Bert
Thanks stuart
the part no is 881440021 ref 17120112 9f fuel filler neck GO1/JE1/GCAB
can anyone be really helpful and advise me the correct one for my car.
its a 1990 h reg karmann clipper cobrio. Automatic.1.8 Carb engine
cheers stuart
I have just fitted the weber 32/34 to try resolve the problem, but after about 8miles (the furthest its ever gone without probs!) it cut out.
When changing the carb I reused the heater element as instructed in the manual, but the connection looked pretty flimsy and I'm sure this should be a sealed unit?
If anyone can advise I'd be most grateful!
R.I.P Dave Wilson
13/02/1982 - 12/11/2006.
To say I've lost my best friend……
cheers stuart
VW list 171 201 129 F as the correct filler neck for a 90 Cab, why does the one you've got not fit?
I HAVE THIS VERY PROBLEM!!!!
Sounds like you could have rust/dirt in the fuel tank, have you checked the condition of your fuel filler neck etc? These sort of running problems often get mis-diagnosed as carb problems, when its often the other end of the system.
1983 1100 C
1983 1100 C
My old clipper had this exact same problem. I had to buy a new filler neck, tank, fuel lines, fillter and pump!!! :evil:
To be honnest you can clean the tank but its a bloody nightmare!
I would highly recommend a stainless filler neck or coating it heavly with underseal or hammerite as this is a classic problem!
miss fire
Can any one help.
Cheers Chalk
1800 golf clipper con.
