getting into petrol tank???
(In Topic #91474)
when trying to get into petrol tank, the white plastic cap? is there any particular way in which to remove this ie special tools??? was scared incase i broke it so didnt attempt to remove it!! also are there washers that will need replaced if i do remove it???? trying to check the fuel pick up is not blocked!! regards ailsa x
myspace.com/ailsa_rockart
There are special tools available if you really want to buy them, but I've found that a screwdriver or two can be wedged in the 'slots' and turned. It shouldn't be that tight, its not a thread or anything, just a seal you're pressing/rubbing against.
PS its quite easy to break, especially in winter/cold weather when the plastic is more brittle.
thanx for the reply! are the caps quite easy to replace?? how much are they??? just incase!!!!!!!!!!!!! x
Not too hard to replace, obviously its best to use a new seal. Just be careful its seated properly because its an easy way to generate a leak you never had before! They cost around ?10-20, depends if its a GTI (level sensor only) or carb (level sensor and fuel pickup too).
