german and swedish tanks?
(In Topic #74812)
whats best
german swedish
euro car parts?
If I were you I'd unscrew the sender from the tank (you can get to it via access hole plate in bodywork), and see what you can fish out from there (or flush out with parrafin). New sender seal recommended too as they can leak or cause (the somewhat common on Mk1's) petrol smells.
Cheers,
Mark
the cars runing a 16v on twin carbs no return using a gtiinjection tank
i fished out ones and tones of rust from the bottom of the tank(where the filter is )
ive replaced the fuel line fuel pump and fuel regulator and blown into the big breather (heard bubbles in the tank so sume thats ok
but alas no fuel pressure at all so im asuming that theres rust in the swirl pot blocking the 10mm output to the edge of the tank ?
im not sure how i could get all tyhis rust out i tried a magnet and that got loads?
im thinkign drain the tank and blow my air line through it then wash through with water jet spray?
