fueltank, easyiest way to clean it out
(In Topic #77223)
many thanks
simon
i always have the last laugh
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
Just try to run it nearly empty first and be carefull
many thanks
simon
<a href="
They cost peanuts, but should do the job admirably.
I've seen a small magnet (size of tictac), mounted alongside a mirror, and a larger magnet (size of three aspirin tablets) mounted on its own.
Whether you clean the tank out with them or not, they're great for recovering dropped bolts from inaccessible places - or for making sure they don't drop into inaccessible places in the first place when you remove them.
Ali Cabrio
Mars Red 1.8 GTi Cabrio 1985
Seat Covers
Scratches
Leaky roof
1 million smiles per hour
Seat Covers
Scratches
Leaky roof
Obviously a magnet won?t pull out any of that. People have reported Hoovering out the stuff via an old fuel pump or an airline pump?
:dontknow:
:dontknow: Hope this helps …..Cheers…………
many thanks
p.s. how the hell did u get road debris in the tank?? and red brick lol
<a href="
In theory you could syphon it out into a bowl on the ground outside if you like the taste of petrol. :roll:
The road debris is thrown up from the wheel. Stick your head up the wheel arch and see how much mud there is, all that goes down your rusty filler pipe into the tank. This with the water that gets in then clogs everything up, makes it run like a dog and eventually knackers your meter head.
It will explode :cry:
The only safe method is with an air compressor and suitable pick up gun , as described . The road dedris is easily digested when you have no fuel filler neck [because it has rusted away] . I wish i had kept the picture of my filler neck when i removed it and then you would see why .
……..Cheers…..
thanks for the replys guys
much appreciated
painted me rocker cover today to and the little strips of metal and my fan cover, got my audi smooth style door handles to, fitting them tomoz hopefully. then the custom manifolds to accpet the r6 carbs, and away she goes to the spray shop (when ive saved up
simon
<a href="
