Fuelling problem - no really!!
(In Topic #75641)
I have an '83 Gti that stopped running sometime ago and which I should do something about.
It began hiccuping and in the end would start fine but soon died. The fuel pump (then new) would get louder as the motor died. It would run for perhaps a minute or so.
I did take it to an expert! Who charged me ?85 to tell me it was water and rust despite the new fuel tank and recent replaced filler neck. I drained the tank - no water or rust came out and checked the pump filter - ditto then lost interest.
I'm tempted to source a complete injection system from a recent runner. Unless someone can suggest where I should start looking. Once I've got it running I can then decide what to do with it.
Barkstar
Did the fuel lines get cleaned out or may be they are still full of crud?
Was the filter on the meter head replaced?
Petrol does ?go off? if left for a long time so it might me worth putting some fresh in when you are sure the tank/lines/filters are clean
Really I'd like to spend as little as possible because I might put it on Ebay or even break it. But if I can sort out the fueling it might be love all over again. It was a hoot to drive.
Barkstar :dontknow:
And I put a pipe on the tank outlet to catch any of the return fuel as it filled the tank back up and nothing came out. Might be nothing.
At least it's not the tank! And the clutch isn't seized either.
Barkstar
1983 1100 C
1983 1100 C
I hope to go through the whole thing in the next few weeks. I did replace all the metal fuel piping with high pressure rubber hose sometime back. I'm not sure about the problem being a vacuum, can't that only be created on the side of the pump that sucks? As the car runs exactly the same sucking on the tank or on a jerry can of fuel I'd think it must be on the push side of things That said though I get most of how K-Jetronic works I have no idea what the accumulator actually does.
I did wonder if it might be a problem with the return side, but would that eventually stop the engine?
Thanks for the input
Chris (barkstar) :roll:
May be nothing, but sounds like the car is running ok when the cold start system should be running - i.e when started from cold. This would add the warm up regulator into the equation which does have some control over pressure duin cold start :dontknow: . Not sure about the fuel return, the pump should have a pressure relief valve to prevent to much presure building up if there is a blockage.
From what you say the pump/tank end of things should be fine so I would be looking at the bits in the engine bay now.
1983 1100 C
1983 1100 C
If you did not use fuel hose suitable for unleaded petrol it is likely that the inside layer of the pipe is breaking down. This could be causing a restriction in the flow. Might be worth letting it die, release the pressure in the fuel line and see if it starts easily again.
The only sure fire way to test is to get a fuel pressure guage on it and do the series of system pressure tests. This will show where the blockage is. In my view it is one of following:
Partially blocked supply line.
Defective WUR.
Defective pressure control valve.
Partially blocked return line.
Rich
It's a while since I last drove it, but I recall if it started to died you could clutch in and rev up it would run a little further. As I said it missed a few times over a few days, then got worse and became undrivable.
Ric Wood's, who took a look at it said they'd found rust and water in the fuel distributor but none of the fasteners looked like they'd been touched. Though they must have done something as getting it the mile home was a long process.
It looks like its down to a fairly simple process of elimination. Though fixing it might prove hard on the wallet.
I'll put up a new post when I've solved it, it may be a week or two as I'm doing the Lombard Revival Rally next week - www.siteset.co.uk/endurance/ - but not in a VW, sorry.
Any further suggestions much appreciated
Thanks again
Barkstar
