Fueling issue on MK1 Golf GTI Cabriolet/Convertible
(In Topic #122081)
I have a 1984 GTI Cab.
It has been sat for around 2years. Previously it has never failed to start with a battery to move around etc.
Put some fresh fuel in it etc. Engine is turning over but not firing.
After reading a post I tried easy start to rule out spark issues and it does fire.
Next step I loosened fuel pipe to the filter inlet. Fuel is pumping well when cranking. I cannot get the outlet bolt off and didnt want to break it. I have also checked the 5th Injector and there is fuel under pressure getting to it. I have also loosened injector lines on top of the Metering head but no fuel coming out under crank.
After reading another post I removed metering head and the flap/plunger moved up and down when pushed with some resistance and air/suction noise which I assumed was ok.
I am stuck what to do next. I was thinking about getting a new fuel filter or does someone else have more diagnostic checks to carry out.
Many Thanks
Now, I am not great on petrols as I have always had tdi's.
Would this be a vacuum leak?
Any pointers for a GTI novice would be great…
A major vacuum leak would cause this problem also but is quite unlikely, whack some fuel system cleaner in the tank and run the pump for a bit and start it with the flap lifted to get some fuel flowing through the injectors, that should sort it ;-)
When manually moving the flap should it be fairly easy to move but feel like you are squeezing air out with like a sound as if you were pumping up an airbed!!!
Does anyone know how far it is open upon normal operation so I can run it for a few minutes. Would prefer to take injectors out as a last resort until I can get it in under cover.
If not I will take your advise and wait for a dry day and test injectors.
argh!!! 1984, do you have an electric throttle switch on the manifold and what looks like a vacuum switch mounted on the metering head? if so then your overrun fuel cut off solenoid could be sticking open and bypassing the metering unit, I don't know where it would be mounted on your car but it would have two half inch or so hoses going to it and an electric connection, one hose would go to the metering head under the flow plate and the other hose would go into the manifold somewhere by the throttle I believe.
out of interest, how are you lifting the metering flap up?
Cheers!
Website Manager
Has the fuel filler neck ever been changed or rusted out ?
The metering head plunger can be removed for cleaning and checking, if there is any sign of rust then in my opinion it will be beyond repair and you will need another metering head.
They are a sealed system but if water has got through the filler neck then when the rusty particles get to the metering head they will just rust it out. Sitting for two years will not help.
I think mine is same as above picture.
Is there a guide for checking the metering unit.
I have owned the car 8 years. I haven't had the filler neck changed since I have had it but not sure beyond that.
Does a vacuum from the engine turning over normally open the flap that I am having to push open?
Thanks in advance. The only reason I want to get it going as I am being pushed to get rid or restore and didn't want a non runner plus the existing bodywork to sort. At least if I could get it running I would only have the paintwork to sort!
92k on clock it too young to die! lol!
The flap should be fairly light to lift and you should feel a change in pressure once the fuel pump runs
My guess is still the solenoid if it is fitted, if not then yes you may have varnished metering head but there is a fuel filter before it that really should be stopping c**k getting through :-)
have a good look for the overrun solenoid and just clamp the pipe shut so it isn't able to bypass the metering unit, that has to be the easy option, I think it is attached to an extra relay on top of the fuse box if that helps
Website Manager
The vacuum and throttle switches work in conjunction with the TTS and CSV to provide a burst on fuel enrichment when the throttle is pressed quickly and the TTS is not up to temperature.
Was this different on 1984 cars ?
Hers is a 1993.
Bypassing the AAV results in 5th injector spraying upon turnover and the flap in the metering head moving up and down itself resulting in the engine firing. Unfortunately I am out of fuel so not sure if its the solution although I put 10L in and seems to have gone very fast. Off to get some more fuel tomorrow.
Does anyone know how the AAV should be in operation? Open/closed etc? Thanks
Not sure about what years had acceleration enrichment, thought it was a later thing and that the overrun bypass had been fitted earlier as a fuel saver, normally the K-jet metering unit is capable of giving acceleration enrichment but I think it couldn't quite cope when cold:-)
sounds like you may be getting to the bottom of it but I am sure you would have been giving some throttle whilst trying to start it which is pretty much what the aav does anyway! maybe all that fuel has cleared the system a little!
