Fuel System Cleaner
(In Topic #89422)
Fuel System Cleaner
Redex petrol injector fuel system cleaner.
Is this what I wanna be using when I flush my petrol tank??
I was thinking…
Change filler neck…top up and flush..top up and flush again….change fuel filter. hey presto.
Does this sound okay? or shall I do it differently?
All help much appreciated.
I was thinking…
'83 Black GTI Cab on BBS RAs - DreamBoat 3000'
Resto = http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=67552
If only it were that simple. To properly flush the fuel tank, you need to remove it (which means removing the rear axle) and thoroughly clean out all the petrol, then vacuum out the rust/dirt. Even then, you'll probably find the inside has flaking rust/paint. If so, its time for a new tank.
oh jesus.
Expect some hundred questions soon.
