Fuel starvation?
(In Topic #88410)
Fuel starvation?
First thing to do is check the filler neck - if that is rusting, the bits will drop into the fuel tank and then eventually get sucked through the fuel system (especially when the car is run on empty). Secondly, lift up the back seat and you'll find a black cap (depending on age of car). Unscrew that, disconnect the fuel pipes and remove the brass plate (if its stiff don't hit it with anything metal - sparks and petrol don't mix!). Now you'll be able to see into the fuel tank. Fix a magnet onto a piece of string and lower into the tank and see what it comes back up. If its full of debris (bits of rust/sludge) the tank will need to be cleaned out.
Basically, the problems you have sounds like crap in the fuel system (the technical term). The 'noise' you can hear maybe a blockage in the fuel pump. As you look at the car from the rear, the pump is in front of the right rear wheel.
To solve this you can either replace the filler neck, fuel lines, fuel pump and fuel filter or flush out the whole system (and still replace the filler neck if rusty).
Danny
Mk1 GTi White Cab '86
Mk4 TDi
Mk4 TDi
Fuel problem
Looks like a busy weekend for me…….dannyboyblue said
Sounds like debris in the fuel lines or fuel pump.
Danny
Thanks for info.
Andrew.
