Fuel starvation when picking up revs
(In Topic #133786)
Hi guys
My son and I have just bought a 1989 gfi cabrio mk1 golf it's awesome but I have a problem with it missing (fuel)
When the revs a kept under 3000 ,all ok but when you accerate through the rev range towards 5000 the car misses
There is a noise coming from the rear of the car by the drivers rear wheel ,thought it was the pump but it appears to bbe the accumulator can anybody help
there is a pump under there to by where the accumulator is, theres should also be a lift pump in the tank to assist it, lift up rear seat and you will see a black dish with 3 screws holding it down, remove there screws and you will see the sender unit with 2 pipes and an electrical plug.
heres mine
check you can hear this one running also as a start, if not remove it by removing the 2 pipes and the plug and knocking the outside edge round (anti clockwise to remove) and pull it out, be careful as you fuel sender is part of this too and it all only just fits out the whole, i brought a new pump from gsf last week for 11 quid i think
if this is running you could try changing the filter, the big one in the engine bay and i think theres a small one in the main fuel pump also theres one on the bottom of the lift pump (or transfer pump) in pic above as golfs are common for having rusty fuel filler pipes resulting in loads of rust and crap in the tank ..
see how you get on
heres mine
see how you get on
Thanks very much for the info very useful I will contact gsf for the pump,
Checked the fuel neck and there is small holes at the top so I'm gonna change asap,
Is that noise from the accumulator by the pump outside the tank is it suppose to make a gurgling noise ?
mine made a gurgling noise when my lift pump died as the main pump was doing all the work, don't go and buy one yet mate have a look at yours first, yours might be ok and the money can go elsewhere if that isn't your problem. And defo not worth changing yet if you have a knackered filler pipe, get that done first and go from there
My accumulator was making a squealing and gurgling noise...I changed the in-tank lift pump and now all is good, running great with no odd sounds
Thanks for your help guys my son and I love this car ,got the fuel filler from gsf £39 plus vat, gonna do the filters and lift pump ,I will let you know how I get on
Best regards Dirk
Best regards Dirk
Thankyou guys for your help my sons cabrio is not missing driving lovely but went down to collect my filler neck and it looks a bit different from what's on there ,any advice?
Best regards
Dirk
Best regards
Dirk
Best regards
Dirk
Best regards
Dirk
make sure its the right one there are different ones, and gsf are well known for giving you the wrong stuff, hit and miss with them mate, best to get the old one off and try it if its no good go back to gsf with the old one and ask for one the same
Cheers Matt it is wrong I will cahse the rite part
Best regards dirk
Best regards dirk
