Fuel Starvation on a MK1 Convertible
(In Topic #74977)
My car holds back or cuts out when under load, I've renewed the fuel filler neck, plugs, leads, dizzy cap, no rust appears to be coming through the fuel lines, carb is clean, valve in the air box appears to be working, manual choke fitted and the car has no mods.
Any ideas?? Pleeeeeeease?
I've replaced the fuel filter but not done the other stuff, how can I check the fuel flow or carb float position, is it simple or should I buy a Haynes manual?!
Sharkey
Ha Ha I can Laugh!
I HAD exactly the same problem for months, but i think i have eliminated it now eventually. Try changing or removing the reservior, (i Bypassed it, till i can get another) car goes like a stonker now! also try looking at the fuel sender pickup under the back seat, might be clogged. PM me if you need more info, there isnt much i havent done/changed to rectify the problem. What Carb are you running?
hope this helps
doug
Man that post was years old LMAO :mrgreen: Moved onto GTI now, and a whole lot of new problems
Trial and error i guess mate, trouble is they dont make the res no more and chances of finding a goodun are slim. :dontknow:
GTI all the way - less hassle!!!!
keep me posted 8)
but recently its just doing the same crap. it goes when it wants to go. ive also changed the main fuel pump but i think its the actual main pump thats giving me problems again. any ideas?
MINE WAS RUNNING BAD AND IT TURNED OUT TO BE THE RETURN FUEL PIPE BLOCKED.CLEARED BLOCKAGE NO PROBLEMS SINCEGeorge87 said
Hi. i have a gti convertible. i have feeding problems to. ive changed the pump under the seat.
