Fuel sender
(In Topic #75010)
Fuel sender
Right removed rear seat, but how do you remove the sender did try prising it but didn't want to go to mad but seems really stiff. Any ideas.
From memory, the plastic part under the metal cover rotates about 20-30 degrees anti-clockwise, and then can be withdrawn.
Cheers Mate will give it a go Sunday.
Yep, that's right, just twist it! Worth replacing the O-ring seal under it too if not done before. They get 'fat' and don't seal, you'll then have a strong fuel smell in the car and leak when you fill the tank right up. It's only a couple of quid from VW :wink:
