Fuel Pump
(In Topic #76453)
Fuel Pump
If you fancy doing it yourself, get a haynes mate. From what i've read it doesn't seem to be too difficult (but I don't like messing with things like this too much, that's why I left it to my mechanic!).
Good luck!
you sure it's the pump and not a wiring fault/ relay etc? if you can, check your getting 12v (or as near as) to the pump when you turn the ignition
new pumps from VW are around ?87.. a relay, well.. Crazy should have some :wink:
took me around 20 minutes to replace mine
