Fuel Pump Woes?
(In Topic #77566)
Fuel Pump Woes?
Got up this morning to go to work and i think my fuel pump has packed in. Usually when you turn the ignition key you hear a "whirring" noise as the back of the car - i presume this is priming the system - but it is silent.
I tried bump starting it to no avail, so i`m waiting for the RAC to come out now. Are there a couple of pumps on an injected 1983 1.8 Gti? And i`ve done a quick search on the web, and they seem to be ?80! Is this right? Any help will be greatly received
Stay out of the black…
And into the red….
You get nothing in this game for 2 in a bed!
And into the red….
Regards Volkswarren
& T Reg S1 GTi Project, Still Looking for Series 1 GTi's or a 16S Oettinger to restore (Complete Cars only) or an A reg Lhasa Green or White Gti to restore, also consider Black, Red or Blue, Project Wanted anything considered WHY
What amp is the relay? Is there any fuses too i should be checking?
I will have a quick poke around the relays - and see if i can suss it….
And into the red….
And into the red….
quick way to know if it's a wiring fault or the pump is to remove the live and earth from the pump, stick a multimeter on it then try starting the car and see what voltage your getting (should be 12v but when the engines turning expect a bit less.. IIRC around 8-9v).. if you get nothing, then it'll be the relay, fuse or wiring at fault (which is nice and cheap)
brought my fuel pump from VW last year and it was ?89
http://cgi.ebay.co.uk/VW-Golf-Mk1-gti-cabrio-FUEL-PUMP-RELAY_W0QQitemZ4620840550QQcategoryZ9889QQrdZ1QQcmdZViewItem
i think it is a dodgy relay - so will be placing a sneaky bid on that e-bay item.
And into the red….
And into the red….
there's so many subtle changes between the earlier and later series 2's… never mind series 1's 8O
