fuel pump strange noises
(In Topic #79340)
do i need a new one do you think,
if so would my mk2 donor cars fuel pump fit and will it make any difference to how the engine is set up
thanks guys
rebuild in progress....
i think my fuel pumps knackered any advice on replacement please
and QUICK !!!!!
cabriaulait said
replacement
I think you summed it up there matey!!!
They normally tend to "go" so quickly, you don't hear any noises. Sounds like you caught yours saying its final goodbyes!
I got a replacement from GSF - About ?80. Looks ok and has not given me any probs yet (just over 2 years old).
Do a quick check to make sure you power to the pump before you shell out though…
AL.
My Build Thread
Not 100% though so you caould have a look. They have the same K-Jet system at the end of the day, so fuel pressure etc would be ok!?! :dontknow:
My Build Thread
The feed pipe from the tank goes directly into the filter on the cabby, but goes into the pump housing on the Mk2.
They are also different part numbers and the Mk2 looks to have some sort of strange strainer attathed to it, dunno what thats all about. :dontknow:
Cabby part no. 171 906 091 A, Priced at ?120.00 +vat from VW and its on a good discount code to them, so do some pleading and you may get at least 10% off recomended retail, which aint bad for a genuine part with two year warranty.
Mk2 part no. 191 906 091 A
Or you could just get one from GSF.
Mk1 Golf GTI 83 Y reg in Lhasa green
Rear disc conversion
Lowered 20mm
14" Campaign Pirrelli P Slots
Lowered 20mm
Keep us posted.
Lowered 20mm
Lowered 20mm
Ended up having to fit a new tank , pipe , filter and pump as well as blowing out all the fuel lines with a high pressure hose , expensive but its worth it - it runs really well now .
Racing is life . Anything before or after is just waiting - Steve McQueen
no fuel!!!
no wonder it was making funny noises
geezer said
just had exactly the same problem on mine - would idle all day but not rev at all under load , fuel pump making strange noises . Check the short fuel pipe that runs between the pump and tank , on mine a dented tank had lead to this pipe and the pump becoming full of grit , would flow enough for a good idle but not anything else . Dont check that pipe if youve a full tank of fuel as you'll be sat there with jerry cans all day .
were did you get the pipe from please need one
JOEL GTI
1979 mk1 c 1.1L 33k sold
1983 mk1 GX 1.5L sold
1983 mk1 gti 1.6 cab sold
1984 mk2 polo 1.0 rat sold
1982 mk1 gti 1.8 sold
1984 mk2 GTI 16V vw motorsport project 16V very rare striped dead!
1985 mk2 GTI 8V runing 140BHP (track car) striping! Dead
1986 mk2 GL 1.8Ldead
1987 mk2 GTI 16V SOLD
Lots of mk3 gti's vr6's and a tdi all sold
1992 mk2 GTI 8V runout edition sold then bought then sold the bought back and striped!
1990 mk2 GTI 8V in tornado red new car
