fuel pump relay problem.
(In Topic #98895)
the fuel pump doesn't start when ignition is turned on. now it could be one of many problems, but the first i thought of was the relay.
when the ignition is on and i remove and replace the relay there is no click. should it be audible or could you feel it as you push the relay in and out?
hoepfully this is the culprit and i dont have to spend my weekend going through the wiring from pump to batt!!
<img src="http://www.sirgeekalot.com/piccys/forum_sig.png">
HELP
Is it connected to the main lead on the coil anyone got any idea of the colour/s on this wire?
So many people have theories about my golf not runing but nobody can fix it as well!!!
cheers dave
