fuel pump question.
(In Topic #78381)
fuel pump question.
fuel pump
1272 driver with a magic tree!!
fuel pump
They tend to give all or nothing, rather than intermittent failiure.
My money is on you still having a problem - Sorry…
Keep us updated though…
My Build Thread
arghhh
relay
frustrated!!!
still it happened at the right time of year for me to work on it..if this happened in november hed be in the garage for months.
mk1 gli cab
tubes
Regards Volkswarren
pump
Fuel pump
Timing is out
Fuel blockage
Breather problems
Airleak or Incorrect mixture
Faulty hall sender (dizzy)
Faulty iginition module (see haynes for quick test)
Low fuel pressure (faulty pump)
I have had a faulty pump which allowed the car to start but would miss, backfire and stall when driven, as volkswarren mentioned they can die slowly, but you would be unlucky to have pair if you have changed it. You say you have done injector test does it act like video below. Also had dizzy problem but this would just die instantly, tacho dropping to zero.
Does it start ok after it has died or do you have to wait before it will start again?
http://www.taunusfinland.com/tiedostot/ford/K-Jetronic/kjetvideo.mpg
it will start again after dying,and will idle smoothly i can increase the rpm slowly but as soon as she reaches the 1200rpm mark she cuts out..the pump seems ok the injectors pumped out a lot of petrol when i tested them just like the video..do you think it could be some kind of air /breather problem? because the fuel delivery seems ok? any help is greatly appreciated guys..thanks for the replies
fixed it
