fuel pump probs GTI
(In Topic #92506)
Life Member
fuel pump probs GTI
the question is, is there a relay or something to make the pump work? if so where is it located and where would i get a new one?
Web Team
Put you finger on it as you switch on the ignition, you should feel it click if it is working.
The INJECTOR TEST will show you how to make up a jumper wire to check that it is actually the relay that is at fault. You can get them from GSF etc new or Mr Quiff 2nd hand.
Life Member
Life Member
it must be ok as mine looks bear as well suppose some could be for things we ain't got like air-con power hoods etc i don't know what they are for either :dontknow:LuckyStrike said
Should my 1981 GTi have all those relays? Half seem to be missing!!!
1 (free)
2 Inlet manifold heating (Carb) / Fuel pump (Inj) / Glow plugs (Deisel)
3 Seat belt warning system
4 Gear change up display (Formel E, GTi)
5 A/C
6 Twin horn
7 Fog lights
8 X relay
9 (free)
10 Wash-wipe interval
11 Rear windscreen wash/wipe
12 Hazard warning lights
13 Seat belt warning system
14 Seat belt warning system
15 Headlight dim-dip
16 Cold start valve
17 (free)
18 Coolant temp gauge (Inj, Diesel)
1988 1.8 carb Golf Clipper
Web Team
Life Member
Life Member
