Fuel Pump Problem
(In Topic #108157)
Fuel Pump Problem
Then car then cut out and would not start smack back in the middle of Maidstone right on a roundabout causing a few traffic problems. Called RAC and got a very knowledgeable guy who called the problem straight away.
So do i have to get a new pump or is it likely to be a blockage ?
I think i know i need a new pump but heres hoping !!
Can be hard to get the pump out as the fitting corrode into place - buy the unions and washers - will save you a little time
part nos 533201220 comes complete with the unions - you'll also need the two sealing washers part nos N0138128.
The braided line with the unions is ?25 - the washers are 22p each.
Hope this helps
M
mines started making a racket and I think I will have to replace
mondoakimboagogo, sent you a pm about the pump
<a href="signature2.jpg picture by jools182 - Photobucket"><img src="http://i88.photobucket.com/albums/k182/jools182/signature2.jpg" border="0" alt="Photobucket"></a>
The swirl pot in the tank is clear now, as is the pick up pipe, but it seems to be struggling to get fuel out the tank - fuel level in the filter is a lot lower than usual
So my question is - is the pump gravity fed from the tank, or does it suck the fuel out?
