fuel pump not priming
(In Topic #95079)
ok the pump used to prime but now it dont and it takes a good 30 sec to a mintue to start after its left for a a few hours , but starts fine when cars warmed up,
and i can hear a little buzzing when the cars on so the pump is working so could it be the relay :dontknow: or anything else i can check?
thanks
btw the only thing i had a prob with the fuel side is the the wires came out the cold start plug which is now sorted but b4 i repaired the wire the pump still never used to prime but started quiker then now but a few times it had flooded casue it to misfire which i think it was to do with the cold start not connected
thanks
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=2376&highlight=relay
Faulty relay ? :dontknow:
The relay that activates the lifter pump is timed - enables the lifter pump to run for a couple of seconds only - ie lifter does little work throughout its life.
So start at the relay - no luck - migrate to the lifter pump (there is a detailed post on how to access this complete with photos) It may be the filter to the lifter (if fitted - some had a filter, some not) is clogged - or it may be a failed lifter - although I doubt it.
I obtained a new lifter pump from VAG a short while ago - ie still available. [Now safe and sound in its VAG box in my spares locker …]
Hope this helps
MP
