Fuel Pump Confusion...
(In Topic #154585)
Forgive me if this sounds like a bit of a dumb question…
I'm a little confused as to which type of Fuel Pump(s) I should have on my particular model (Mk1 Clipper, 1.8 Carb) and wondered if somebody could clear this up for me?
After a quick inspection of the car, I can only find a mechanical fuel pump bolted to the engine block. Is this right or should be there be another pump at the tank end of the car also?
I have read various topics regarding pumps and their locations and was half expecting to see a pump at the rear of the car but can't see anything.
The current sender unit in the tank has feed and return hoses attached but no lifter pump, and there is no fuel pump connected to either of these hoses in the tank vicinity.
Is this setup right or am I missing something?
New pump has arrived, fitting it this weekend!
On sharp corners with less than half a tank of fuel, it splutters. Any ideas on what I need to do to fix this?
Does it have an external swirl pot somewhere that I would need to change?
1. change the fuel tank for mk1 gti type and move the fuel pump back under the car where it belongs
2. fit a lifter pump in the tank and a fuel reservoir somewhere before the main pump. again move the fuel pump back where it belongs!
http://vwgolfmk1.org.u…t-hand-cornering&start=20
