fuel pipes needed
(In Topic #122351)
fuel pipes needed
Reason for asking is fuel lines can be one of the reasons for poor fuel supply, or rust collecting in filter, but only one of many.
Most likely they mean the ridid lines that run fron the back of the car to the engine bay, two lines, one feed and one return.
as for where to get from check out the link below to crazys website..one possible source.
can also be made up with the right kit, or even possible to run rubber fuel line as an alternative.
http://www.golfmk1.co.uk/Items.php?cat=ALL&group=FUELLINES
infat check out the post below which was just a couple below this one.
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=80994
1988 1.8 carb Golf Clipper
i asked the bloke who will be doing the fitting and he's said if i can get a reel of brake pipe he will be able to make them up, from the link you posted i'm going to chat to him about the nylon air line.
he has said they have corroded and thats why they need replacing.
