fuel pipe thingy with pic.
(In Topic #97527)
rivage just failed mot on coil spring and rear brake hoses, "easy" i thought. until i looked. my worry is changing the hose on the osr as it sits behind, what i thought was fuel pump. from the pump there is a metal pipe that then runs along side the tank. cant see where it goes after that. the metal pipe is so corroded it looks like it would crumble if disturbed, see pic. the pipe just above the flexi
See below for when the nice MOT didn't like the look of my rear flexis;
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=35900&highlight=
If the are unlucky you might find that the unions between the flexi and metal brake pipes are seized and destroy the metal pipes too, at both ends on both sides of the car……
Both the fuel supply and return pass through this unit.
I can supply this at ?10 +P+P+VAT
The metal pipe that goes from this to the back of the fuel pump can be replaced with 10 or 11mm bore unleaded fuel hose - again I can supply this stainless braided with clips.
Rich
