Fuel or ignition??? anyone had this problem???
(In Topic #72786)
Ive since changed the fuel filter and found bits in it and water (but it looked like it hadnt been changed since it rolled out the factory as it has the old type filter and fuel pipes) I also drained the tank and found no water. Ive changed the spark plugs and leads. It runs better, in that i mean she drives but is lacking power big time, but when she gets hot she smooths out a bit, and if i switch her off and back on i either get full power back for about 5mins, or no change.
WHAT COULD BE BROKEN??????? Id appreciate any advise
Chris C cfcapes@hotmail.com
I would suspect fuel delivery and is likely your fuel pump is not delivering the pressure or volume of fuel. This can be caused by other problems with the tank breather being blocked broken or the accumulator having failed.
check the inlet pipe on the fuel pump as well, see if its full of rust & crud.
Garage advised to replace tank… I've not bothered, but I noticed over the weekend that symptons just coming back (stuttering with application of throttle - but ok with v light throttle. So - I'm going to find a tank and get garage to fit. Should then solve problem.
Clearly - your cause could be many, many thinks… but I put a post up on the forum and I got 6 replies all pointing to rust in tank. Perhaps you may be lucky - change tank - and you'll be good to go. Hope this helps.
